Help! stuck injector? bad o2?
just now about 10 minutes ago i was driveing along... then i lose all this power and my engine starts misfiring BAD ... i pull off... shut the car off and pull up the autotap.. re-start... it fires up perfectly... runs fine for about 15 seconds... and then starts shaking... misfireing etc.
my bank 2 o2 is at 1107mm and doesnt move
my bank 2 short trim is at -40%
i have no idea if an injector is stuck open ( 30# svo's)
or my o2 is shot...
Or, hell, you can do the opposite. Swap the O2's between sides and see if the problem follows the O2s. Whichever is easier for you.
Dope
<strong>o2's where shot... runs perfect now</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You replaced the O2 and it ran fine after that?
Were your O2s coated? What kind of fuel do you use?
