which crank?
Old Mar 6, 2007 | 04:28 PM
SSdreamz's Avatar
Default which crank?
now im only limiting the selection to two cranks. the Eagle 4 inch crank, or the new compstar crank. which one would you all choose if you only had those two to choose from? and why? and before anyone asks....the budget doesnt allow for a lunati, and the stock one isnt a 4 inch stroke, or i would have just used that.
Old Mar 6, 2007 | 04:35 PM
brad8266's Avatar
Compstar, I heard too many bad stories about the Eagle cranks.
Old Mar 6, 2007 | 04:50 PM
cablebandit's Avatar
i turned my 408 to 7000rpms with the eagle crank and rods...no probs. No experience with Callies.
Old Mar 7, 2007 | 01:08 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
Compstar all the way. I've heard some bad things about eagle. If the compstar crank would have been available when I ordered my engine, I very well may have gone with a 383. But like you said, lunati is way too expensive, and I can't trust the Chinese steel of the eagle...
Old Mar 7, 2007 | 04:21 PM
SSdreamz's Avatar
ive heard the eagle cranks are of "import" steel. what about the compstar? is that import steel?
Old Mar 7, 2007 | 04:33 PM
JPH's Avatar
JPH
eagle will be fine for your application. just make sure the machine shop checks straightness and balance.
Old Mar 7, 2007 | 04:34 PM
SSdreamz's Avatar
also note that the price difference is only 100 bucks
Old Mar 7, 2007 | 04:44 PM
ThunderStruk's Avatar
100% Callies. I have had way to many issues with Eagle cranks!!!!
 Michael S. Palmer
Old Mar 7, 2007 | 04:46 PM
SSdreamz's Avatar
im not sure what the difference is...this one just says compstar...and then there is callies......so whats the deal?
Old Mar 7, 2007 | 05:18 PM
hotrodrx7's Avatar
I would like to know also. Is there a difference between the compstar and dragonslayer cranks?
Old Mar 7, 2007 | 06:26 PM
SSdreamz's Avatar
maybe a sponsor would like to chime in....
Old Mar 7, 2007 | 06:58 PM
SouthernSilverSpeed's Avatar
lunati.
but on a more serious note. I am assuming you are not racing this car, because if you were, you would spend the money the first time and do it right insted of picking through shattered ls1 parts and rebuilding again. Be happy and spend the extra!!
Old Mar 7, 2007 | 08:47 PM
ChevyChad's Avatar
Compstar is Callies. Think of it like this: Callies is Chevy. The dragonslayer is the SS version, and the compstar is the Z28
Old Mar 8, 2007 | 07:45 AM
bap@Callies/Compstar's Avatar
Here are some answers to all the questions. Anything you see under the Callies name is 100% made in the USA. Compstar products are made overseas. We have never wanted to hide this fact. Compstar is like "Buick" is to General Motors. Now that being said we do specify and supply them with a true 4340 AMERICAN standard of steel to make all the Compstar products. We specify tolerances and do all the finishing work here at Callies so the cranks or rods hold the same tolerances we finish our parts here to. Now I am sure the question is so what is real differences. Callies Cranks whether your looking at the DragonSlayer or Magnum have the Permatough heat treat done (you can turn them 30 under without breaking the heattreat) to them and they are a little lighter in weight. There is also a wider range of strokes available with the Callies line up. (SEE THE WEBSITE) Also they will take anything you want to throw at them. If you look around you will find most of the top LSX Engine builders use Callies Cranks. Compstar Cranks are a perfect crank for the budget minded guy. The Max HP we are intending these to go into are 900-1000 HP. We will only have these available in the following strokes.
4.00 - 4.100 - 4.125 - 4.250 and Stock
As of today we only have the 4.00 and 4.100. We will have the 4.125 and 4.250 by the end of March.
I hope this helps everyone.
Old Mar 8, 2007 | 08:18 AM
ChevyChad's Avatar
Thats good info to know. I think most people on this site are definitely not planning on more than 900~1000 HP!
