Simple question
Old Aug 30, 2002 | 01:03 PM
2002z4evr's Avatar
Default Simple question
What is the sensor that is directly over top the starter going into the block,and can it be the cause of a oil leak? thanks...
Old Aug 30, 2002 | 01:45 PM
Fireball's Avatar
Default Re: Simple question
thats the crank position sensor and I'm not sure if it will usually leak since its o-ringed in
Old Aug 30, 2002 | 02:09 PM
CHRISPY's Avatar
might be your oil pressure sender on the back of the manifold. Have you had your manifold off recently or been tugging around back there?
Cheers,
Chris
Old Aug 30, 2002 | 03:07 PM
2002z4evr's Avatar
No i havent had the intake off, the car has 4,000 miles on the clock. I can see oil on the up most starter bolt and its running down the plastic cover for the starter/bellhousing. I allready took it to the local dealar and they retightened the passenger side valve pan cover and a spark plug. But i still have the leak and its definitly not comming from the back of the valvepan cover because i can see that its dry... Any ideas is greatly appreaciated.ps i like this board much better than ls1.com I posted over there and just got one smarta** reply.
