What peaks higher- 112 or 114 lsa?
Old Sep 3, 2002 | 09:20 AM
11 Bravo's Avatar
Default What peaks higher- 112 or 114 lsa?
I, and many others, always thought that a 114 lsa cam would peak a little higher than a 112, w/ all other specs identical. There is a big thread on ls1.com (I know), and some guys have put out some techinical info that says otherwise. What's the deal, have I been wrong all this time? I kinda hope I've been wrong, cause I'm about to put in a 114 cam in my auto.
Old Sep 3, 2002 | 09:32 AM
CHRISPY's Avatar
Default Re: What peaks higher- 112 or 114 lsa?
Generally a 114LSA cam will peak a little higher than a 112LSA. Probably only 100-150rpm higher though in the 220-224 range.
Cheers,
Chris
Old Sep 3, 2002 | 09:38 AM
11 Bravo's Avatar
Yes, that is what I've always believed. But, go look at that post on the other site in the engine section. They have some compelling info that says otherwise. I'm trying to find some specific information that will show what exactly is right.
Old Sep 3, 2002 | 10:00 AM
Louis's Avatar
2 cars with the same setup, one with the T1, other with the B1, and the T1 will peak higher. Mbaskett Did this in dallas.
Old Sep 3, 2002 | 10:36 AM
CHRISPY's Avatar
Unless it is on the same car preferrably in the same day you cant really compare the two cams. especially two as close as the T1/B1. If it were on an engine dyno with the 2 cams swapped the same day you would have a more accurate representation.
Cheers,
Chris
Old Sep 3, 2002 | 10:52 AM
Viper's Avatar
http://www.ls1.com/forums/showthread...eferrerid=1904
Hey, if u can check out the post on ls1.com.
I started the thread because all I've read on this board.
<small>[ September 03, 2002, 11:40 AM: Message edited by: Viper ]</small>
Old Sep 3, 2002 | 11:40 AM
Viper's Avatar
ttt
