Going to try an aggressive cam and try to pass emissions
230/230 114LSA 4 degrees advance ground in on XE-R lobes. (.60x lift intake and exhaust)
We are thinking it should peak around 6500rpm and idle nicely at 975rpms. With dual 3 inch cats on my MAC headers we are thinking it might pass emissions with a good tune. Compression is at 10.8:1.
Right now I am running a 226/234 112LSA .554/.575 lift ARE custom grind.
What are your thoughts? Remember I am running few more cubes than stock <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Cheers,
Chris
<small>[ September 03, 2002, 02:46 PM: Message edited by: Chris ARE 360 ]</small>
Cheers,
Chris
<small>[ September 03, 2002, 04:23 PM: Message edited by: Chris ARE 360 ]</small>
Thus the relatively large single split on 114LSA. with 4 degrees advance ground in to bring the peaks down a bit.
Cheers,
Chris
I still think a well tuned Hi-Performance car in many cases produces less emissions -overall- than many cars (and semis) on the road today.
Best ET when I was A4 was 11.7 with traction problems. Best mph was 122.60mph.
Still some issues to iron out but should be in the 124mph range all motor in the fall with a raceweight of 3450 pounds.
Cheers,
Chris
<small>[ September 04, 2002, 09:50 AM: Message edited by: Chris ARE 360 ]</small>
