T&D Machine Shaft Mount Rockers
Shane
lifter preload, pushrod length and stand height all the while keeping the adjuster in the proper position so the trunion bearing gets oil is quite a trick. It can be done but it ain't easy.
Adjustable shaft rocker systems like the T&D's and Jesels are overkill in a hydralic lifter engine.
There's plenty of other things to spend money on that will help you more. But..... if you already have everything go for ir!!!
