head gasket question
Old Mar 8, 2007 | 08:09 PM
fast2000z28's Avatar
Default head gasket question
I have the dart pro 1 heads and the tsp 232/235 595/598 cam. Can I use a cometic .040 gasket
Old May 31, 2007 | 11:41 AM
Bill Bowling's Avatar
I also have a set of Dart 205's and I was also looking at .040 Cometic Head Gaskets #202-403.
Bill
Old May 31, 2007 | 02:41 PM
AKRA's Avatar
I have 5.3 heads that are ported with 2.05 & 1.6 valves. I used the .042 head gaskets and after approximately 3000 miles I developed coolant leaks from the rear of both heads. After doing some research, it's my under standing that with an aluminum block it is harder to maintain a truly level surface. A larger gasket (stock 0.058) will help make up for some of the imperfections.
Good luck,
Al
Old Jun 16, 2007 | 04:42 PM
That is one reason I have not ordered the head gaskets yet. I have heard of too many leaks with the thiner gaskets.
Bill
