What is this cam??
Old Sep 11, 2002 | 01:30 PM
RedDevil's Avatar
Default What is this cam??
Sorry pictures kinda big
<img src="http://www.moonliteprinting.com/gtp2201.jpg" alt=" - " />
Old Sep 11, 2002 | 03:15 PM
Fenris Ulf's Avatar
Default Re: What is this cam??
224/224 .578/.578 112 i think
Old Sep 11, 2002 | 03:18 PM
RedDevil's Avatar
not questioning you, but how did you come up with that? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Sep 11, 2002 | 03:25 PM
Ruquick's Avatar
Multiply the lobe lift by your rocker ratio and that will give you your valve lift .340 x 1.7 = .578 3.40 x 1.8 = .612 etc..
Old Sep 11, 2002 | 04:03 PM
ScottyG's Avatar
Also.... this cam does not have any ground-in advance like many of the good performing cams out there.
For instance, the MTI T1 has 4 degrees of advance ground in.
<small>[ September 11, 2002, 04:03 PM: Message edited by: ScottyG ]</small>
Old Sep 11, 2002 | 04:05 PM
RedDevil's Avatar
If MTI's cam has it ground in, would I need to put in a few degrees, if that's possible?
