Ls1 w/ LS6 heads
What would be gains be with just these heads swapped in place of LS1 (241) heads? I also plan to go with a 231/237 .595/.598 cam at the same time.
Or better year how much better do the LS6 (243) flow better then the 241 heads?
I will be putting Comp 1.7 rockers w/ dual gold springs on them.
What do you guys suggest as far as massaging these heads or leave them stock?
There is a shop over here that does head work.
*yes I searched but it isn't working.
I just wanted to know if it was a like a 10,20,30hp gain over stock given everything else is stock?
I looked around for flow numbers but for some reason I can't find the site that I did a while back that had ALOT of head flow numbers.
