spun bearing or loose something?
Old Mar 12, 2007 | 12:16 AM
CASHss99's Avatar
Default spun bearing or loose something?
i did a little test so i was driving home tonight and i went bout 55 60mph ish ,rpms 2500 or so it was the loud clanging tciking noise.. im pritty damn sure it a loose rocker or it aint on the valve straight or something becuase i only hear it on driver side... when its at idle its just normal sewing machine noise hmmmm
it happens when im at a high speed 50+ when im below that car runs great. when its at idle no unusual sounds. when i hit 50+ its very loud then i stop let it idle then goes away.. now ive done 50+ alot already because the speed limit is 45 and this noise has only happened 2wice and oil pressure is normal... i have a stock tune... maybe the car is just wigging out or wuh
Old Mar 12, 2007 | 12:36 AM
MightyBobo's Avatar
You sure it goes with the speed of the car, or the speed of the RPM's?
Old Mar 12, 2007 | 01:40 PM
CASHss99's Avatar
well it only happens when im at a hi speed, but yes when the rpms go up the noise goes with it doesnt get louder but moves with teh rpms if you can get what im saying
Old Mar 12, 2007 | 03:05 PM
CASHss99's Avatar
just checked all the rockers they are all still torqued good.. :-( i hope it aint what i think it is.... when i start it up theres no noise.. when i drove it around for 4 hours or so no noise but only when i get in a hi speed or higher rpms... maybe it just needs a tune baaaaaaaad
Old Mar 12, 2007 | 05:07 PM
OUTLAWZ RACING's Avatar
Did u just put the cam in g5 x3 is kinda big big cams tend to make a little noise
Old Mar 12, 2007 | 05:21 PM
CASHss99's Avatar
yuh i just put it in last week already 300 miles on it stock tune.. you think i should just get the tune and see what happens
