car dies at lights with AC on...
Old Sep 14, 2002 | 03:17 PM
george's Avatar
Default car dies at lights with AC on...
Ever since I had a cam installed my car will die at stop lights/signs 9 out 10 times. With the car at idle I can turn the AC on full blast without any issues. It's only when I come to a slow stop it will die. If I have the AC set to the "AC" setting and on low I can get away without the car dieing. Any other settings and the car dies. Any ideas?
Old Sep 14, 2002 | 04:16 PM
It'llrun's Avatar
Default Re: car dies at lights with AC on...
Too many variables. It could be loss of vacuum, or a charging (alt.) issue, or a problem in the A/C system itself (doubtful). I'd look for a vacuum problem unless you also swapped pulleys recently.
Old Sep 14, 2002 | 04:32 PM
george's Avatar
I did install just the ASP crank pulley when I installed the cam. I do have a M6 so I didn't think the pulley would cause me any charging issues. Do you think adding the ASP alt. pulley would help?
Old Sep 14, 2002 | 05:38 PM
Quickin's Avatar
My guess: Crankshaft Position Sensor
I had the same exact symptoms, no SES ever came on. The dealer found it though. The tech said its one of the items that sometimes won't flash a code. Considering you just installed a crank pulley and a cam it could be it.
Old Sep 14, 2002 | 05:41 PM
XtraCajunSS's Avatar
Have you drilled or adjusted your throttle blade yet???
Shane
Old Sep 14, 2002 | 05:46 PM
george's Avatar
Crank position sensor huh? I'll check that out.
Yes, I did drill the TB blade so it would idle after the cam swap.
Old Sep 14, 2002 | 05:49 PM
It'llrun's Avatar
I'd never have thought of the CPS! Good thinking "FLYLE"! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
