Is crank pulley balanced?
Old Mar 13, 2007 | 08:19 AM
finallygot1's Avatar
Default Is crank pulley balanced?
When pulling my crank pulley I broke a small piece off one of the tabs that the three prong puller attaches to. I know the best solution is to buy an underdrive, but over budget already.
I was going to have my machine shop friend drill one hole in each "spoke" of the pulley so if I need to take it off again I can use the three bolt style of puller.
Any opionions on this?
Thanks
Old Mar 13, 2007 | 09:05 AM
brad8266's Avatar
I can sell you my old stocker. I would not use that damaged one.
Old Mar 13, 2007 | 03:12 PM
Beast96Z's Avatar
I broke a tab off of one once before. We reinstalled it and it ran fine.
Old Mar 13, 2007 | 04:48 PM
Blk97WS6's Avatar
same thing happened to me when i did my cam install. I also didnt want to spend an *** load of money for an aftermarket. I ended up picking one off another board member for cheap. Just post something in the parts wanted section. Im sure there are plenty of people with the stocker sitting around.
Old Mar 14, 2007 | 04:05 PM
FireSilverLullaby's Avatar
yeah i would just get a new one cause its real bad if its not balanced
