Difference - MMS and Thunder 224/112 cams?
Old Sep 17, 2002 | 04:23 PM
kewlbrz's Avatar
Default Difference - MMS and Thunder 224/112 cams?
When comparing the TR 224/112 and the MMS 224/112, what are some obvious differences besides the stated numbers:
MMS 224/224 571/571 112
TR 224/224 561/561 112
The TR224 seems to carry more weight on this forum, why is that?
Old Sep 17, 2002 | 05:03 PM
Scalpel's Avatar
Default Re: Difference - MMS and Thunder 224/112 cams?
I do know that TR cams have some pretty fast ramp rates <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
I don't know how they compare to MMS though <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old Sep 17, 2002 | 09:59 PM
2000SILVERTA's Avatar
My MMS 224 gained me 43 rwhp on THUNDER RACINGS dyno. It has pretty quick ramps, dont know the diff, but it helped me bust a lifter.
BUT, if I could do it all over again, I would go with the Thunder cam.
confused yet?
customer service at TR is outstanding.
Old Sep 17, 2002 | 10:20 PM
Miles in Michigan's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by kewlbrz:
<strong>MMS 224/224 571/571 112
TR 224/224 561/561 112</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Last time I looked, the MMS 224 cam (v3) had 0.569" lift, not that it's a big difference.
The duration at 0.006" for both cams is 275 degrees, which indicates their ramp rates should be similar (since the profiles cross are equal at two points the average slope is equal between those points, makes it likely the curves are similar). They'll at least be more similar than either one is to an MTI T1 or B1, which has slower ramps (as evidenced by the T1/B1's 0.006" duration of 280 degrees). The TR224 and MMS224 ought to both be pretty similar to the MTI C1 cam, which also has 275 degrees at 0.006" of lift.
The TR224 comes with either a 112 or 114 LSA. AFAIK the MMS224 only comes with a 114LSA, but I could be wrong (MMS website is *still* down, so I can't double check). I do know the MTI C1 only comes with a 112 LSA.
