AFR 205 and torquer v3....
Old Mar 13, 2007 | 03:30 PM
blksheep's Avatar
Default AFR 205 and torquer v3....
with the afr 205's and the tsp T v.3 will i have to fly cut the pistons when using stock ratio rockers???
i had heard i may have to just wanted to get some opinions....
Old Apr 3, 2007 | 04:25 PM
nightrunner's Avatar
Mr. Obvious
would like to know too
Old Apr 3, 2007 | 05:19 PM
hammertime's Avatar
Depends on how much you are milling the heads and what thickness gasket you are running. Unmilled, AFR 205's have more valve drop (read: more PTV clearance) than stock. According to Louis @ LG Motorsports, they still have more clearance than stock heads when milled to 59cc.
Originally Posted by Louis
Hi guys, there is 220 thou of valve drop with a milled, 59cc AFR and .040 cometics. There is 200 thou of valve drop on a stock motor.
Any X series( G5, X1, X2, X3, X4, 111/112/114 excluding the xX ( which in most cases, thats install only here at the shop) will fit on a stock engine, 112 or 114. The X3 110 will not clear stock heads, but it will be close on the AFRs. You gain quite a bit of PTV with AFRs. If you are not sure, and want to know what your setup came in at, check it.
The specs floating around here for the G5X3 are 234/242 112+4, so I wouldn't think you would have any problems with a 232/234 cam on either 112, 113 or 114 LSA.
