shaft mount rockers
Old Sep 19, 2002 | 01:47 AM
DONAIMIAN's Avatar
Default shaft mount rockers
could i use shaft mount roller rockers in an engine without a solid set up. im just wondering casue i rev the engine to about 6800 and since its a roller tip i fig i would get more power from that and could use it with a thunder cam because its a 1.7 ratio
Old Sep 19, 2002 | 08:43 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: shaft mount rockers
Stock rocker arms can handle 6800 rpm no problem. Ours are half-roller, just the tip doesn't have a roller. That isn't the important roller of the two anyways.
Jesel makes some stock replacements that will fit under the 99+ valvecovers with some grinding under the cover. That is what I have on my motor. Cost is around $700 a set.
Photo of Jesel Rockers
-Tony
<small>[ September 19, 2002, 08:44 AM: Message edited by: Nine Ball ]</small>
Old Sep 19, 2002 | 04:21 PM
DONAIMIAN's Avatar
do you think that my valve train flexes right now if i did put thoes on whould i notice any power up top from the rockers being more stable
Old Sep 19, 2002 | 05:23 PM
LS1derfull's Avatar
I doubt you would see much power but jesel is probably lighter and would rev faster, and that means springs would last longer too. I think Jesel rockers are important when you have heavy spring pressure and radical lobes because this is what will pound stock rockers and cause bearing failures IMO. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Sep 19, 2002 | 05:29 PM
ls1290's Avatar
Dumb Ass Vette Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Nine Ball:
<strong>That is what I have on my motor. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Tony, what diameter spring can one run with the rocker arms? I have heard that the Cam and Crane arms need modification to run 1.460" springs.
Old Sep 19, 2002 | 05:42 PM
BADZ's Avatar
Moderator
I had to cut larger seats for my big dual diameter springs and Jesel's but im not sure how big as I am now running a high spring pressure.... <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<small>[ September 19, 2002, 05:43 PM: Message edited by: BADZ ]</small>
Old Sep 19, 2002 | 10:46 PM
DONAIMIAN's Avatar
o yea and when i say i spin to 6800 i stay there for a while (freeway race) <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
