What's up with these "reverse split"cams?
Old Sep 21, 2002 | 01:47 PM
One Monkey's Avatar
Default Re: What's up with these "reverse split"cams?
HTM the Valve timeing can be controle in more than one way.. the Intake dose like a diffrent set of valve timing.. Like I pointed out. but the reverse patten cam is not the reason it's making more power. It's the larger intake that makes the power as it moved the valve timing you are talking about... small Ex only cause the power too stay low. a larger Ex would of work just as fine and most likely make more power however the RPM band will be too high for most Street cars.
It's not because of a restricted Intake!
Brent
<small>[ September 21, 2002, 01:48 PM: Message edited by: One Monkey ]</small>
