check out this cam
Old Sep 21, 2002 | 08:39 PM
BYBYC5's Avatar
*Bad Trader*
Default check out this cam
i was brain stormin' and thought of this cam 222/222 569 569 110.5 or 111 +0
might be kinda torqy(sp?) an decent for stock heads and headers, whata ya think? if i end up not liking the 230/224 i might try this cam spec...HMMMMMMMM opinons plzzzzz <img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" />
Old Sep 22, 2002 | 10:39 AM
BYBYC5's Avatar
*Bad Trader*
Default Re: check out this cam
wow no opinons yet, thought som one would be all over this....ttt
Old Sep 23, 2002 | 05:59 AM
BYBYC5's Avatar
*Bad Trader*
ttt
Old Sep 23, 2002 | 03:26 PM
SSINFUL's Avatar
I'd be liking a 224/230 before the inverse.
*Any* cam is gonna be challenged by the stock exhaust system, though. That's just giving up sooooo much hp.
If yer wanting to go w/ a custom job on stock heads, IMO, a 111 or 110 is gonna be peaky. And, probably not too torquey 'cause of that narrow lobe sep.
Old Sep 24, 2002 | 01:50 AM
gto69judge's Avatar
An A4 car requires a wider powerband than a M6 car so I dont recommend that tight of an LSA. The A4 only shifts twice to get into high gear, whereas the M6 is shifted 3 times. That means the rpm drop is greater on the A4 car. (I know, huge stall converters provide a shift extension to limit RPM drop). I suggest a 114LSA for A4 cars to provide a better idle as well as a wider power band. A 224/224 @ 114LSA or a 222/222 @114 LSA with your 3200 converter and longtubes would make a VERY nice combination.
Old Sep 24, 2002 | 06:01 AM
BYBYC5's Avatar
*Bad Trader*
well i was thinking this cam would have a litle more torque down low and peak early.im not to concerned with idle my last FOUR cams have all been 112 or 111
