SLP double roller timing chain ?'s and oil pump
Old Sep 21, 2002 | 10:07 PM
01Tahoetwinscrew's Avatar
Default SLP double roller timing chain ?'s and oil pump
Anyone that has this double roller timing chain...please tell me that they included the ".010 spacer" for clearance between the oil pump and the timing chain. In my box nothing was in there except the timing chain, upper and lower timing sprockets, and the 4 oil pump retaining bolts and washers. Can anyone shed some light to this situation so I can finally get this thing finshed! Thanks.
Old Sep 22, 2002 | 08:19 PM
LS1 BU's Avatar
Default Re: SLP double roller timing chain ?'s and oil pump
The spacers go between the oil pump and the engine block. The slp double roller can is alot thicker. Without the spacers i think the chain will hit the pump.
Old Sep 22, 2002 | 09:21 PM
Yes, I realize what the spacers do....I just want to see if the spacers are supposed to be included with the timing chain set as my box did not have the spacers. Thanks
Old Sep 22, 2002 | 09:46 PM
LS1 BU's Avatar
They are included in the kit.
