Head studs Q.. Moly Lube on block side?
Old Sep 22, 2002 | 02:41 AM
MelloYellow's Avatar
Default Head studs Q.. Moly Lube on block side?
The headbolt holes just go into the block and don't tap into the water jackets, right? I know coolant can fall in when doing head work and you have to blow it out.
But like, if you are using head studs, Moly lube into the headbolt hole is enough. It doesn't need to be some type of waterproof sealant, right?
Just thinking about what someone else said once.
Thx!
<small>[ September 22, 2002, 06:48 PM: Message edited by: MelloYellow ]</small>
Old Sep 22, 2002 | 06:25 AM
BB's Avatar
BB
Default Re: Head studs Q.. Moly Lube on block side?
Right they don't tap in to water jackets or oil galleys. Make sure you clean the head bolt holes real well. You don't want coolant or thread lock in there when you install new bolts or studs. For me compressed air didn't get it all. I had to go in there with paper towel wrapped around pushrod to get it all out and then thread the hole with the old bolt about two times.
I've never heard of putting moly lube in there - I'v not done studs yet. I would be concerned that the stud could back out.
Old Sep 22, 2002 | 06:47 PM
Thx.
Anyone want to commend on Moly Lube on the block side of the head studs?
Old Sep 22, 2002 | 06:52 PM
Sears's Avatar
!Dial-up Director
You do NOT put moly lube on the block side, just the top side of the stud and the nuts to get a consistent torque reading.
Justin
