222/222 .581 .581 112?
Old Sep 22, 2002 | 04:18 PM
jt093's Avatar
Default 222/222 .581 .581 112?
Any good on an a ls1 A4 car w/ Mac headers, no cats, loudmouth, lid?
And will the TB drill-out fix the idle?
Jeff
Old Sep 22, 2002 | 05:14 PM
LS1derfull's Avatar
Default Re: 222/222 .581 .581 112?
I dont have A4 but this is about my cam specs and this thing runs good IMO, see my Sig.No gears, no headers or off road y-pipe and stock tuning other than Hpp3. 3550 lbs. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Sep 22, 2002 | 05:15 PM
LS1derfull's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by LS1derfull:
<strong>I dont have A4 but this is about my cam specs and this thing runs good IMO, see my Sig.No gears, no headers or off road y-pipe and stock tuning other than Hpp3. 3550 lbs. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
Old Sep 22, 2002 | 09:57 PM
jt093's Avatar
damn, runs good <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> ! I think I will go with that cam then. Thanks
Jeff
Old Sep 22, 2002 | 09:58 PM
jt093's Avatar
BTW, I know I have an A4 but on your M6 does it idle rough?
Old Sep 24, 2002 | 10:28 AM
Raughammer's Avatar
D(irecto)r Pepper
Here is some info on the C1-Hammer cam.
222/222 .566/.566. I hope it help you make a decision.
Hammer Cam, User Comments:
If you want one.. here is some info.
The lobes are standard order. You can get it from most any speed shop.
Part number 54-000-11
Grind number LS13714R/3714R HR12
Serial # R 4360
I bought mine from MTI
281 870 8787
Cam specs: Comp Cam/ MTI Hammer cam
Duration at .050 intake/exhaust- 222/222
maximum lift with 1.7 rockers- .566/.566
lobe separation- 112
Manufacturer- Comp Cams
Vendor- MTI
Your car type (auto/manual)- A4 with a big stall
displacement- 346
headwork? (yes/no)- yes, MTI stage 2
headers? (yes/no LT/med/shorty)- FLP long tubes
na/force-fed/bottle-fed- N/A
computer reprogrammed? (yes/no) Some MTI tuning to get rid of EGR/Air pump SES lights.... they also raised my shift points and rev limiter.
throttle plate drilled? (size) Yes, 13/64"
Goals= Drag/ Street
Is it too aggressive/not aggressive enough/just right? It's about right for me... not too big.
Lope- Lumpy, but not annoyingly so.
Additional comments: This cam combined with my heads propelled me to 10.86 all motor.
10's with a daily driven street car?
With a "little" 222/222 cam? SWEET! I still can't believe it.
It makes good use of fast ramps yet still keeps the duration and l/s down in a usable "street racers" (IMO) range. 4 degrees of advance are ground in.
This cam took me to the 10.8's and yet is VERY small compared to some of the others you will see listed on this website.
I shift around 6400 R.P.M's.
Here are some other Hammer cam comments:
Nine ball says:
MTI Stage 2 heads
222/222 .566/.566 112 "Hammer" cam
FLP long tubes
LS6 intake
Custom PCM
Borla Catback
MTI air box lid
ASP crank pulley
= 410-420 rwhp on an M6 car on average, without any driveline "dyno tricks" (aluminum flywheel, carbon fiber drive shaft, lighter rims, less rear gearing, etc..) Some guys see 430+ rwhp with the same setup I have outlined here.
That setup also comes with a 1-year, 12K mile warranty when installed at MTI. Feel free to beat on it, just don't use nitrous or turbos/superchargers on it or the warranty is void.
Note, For M6's: If you intend on drag racing the setup, go with 4.10 gears. I'd rather recommend a 12-bolt rear end though. I broke 4 stock rear end setups before finally getting a 12-bolt that could handle the abuse. Get 3.73s if this will be primarily a street action car. The 4.10s tend to spin too easily off the line on the street. 3.73s are much easier to control in low traction conditions.
Get the 6800 rpm limiter, you will be shifting around 6600 rpm and do not want to hit the irritating limiter.
1MaddSS says:
I just finished installing MTI S2s and Hammer cam on my SS a couple of hours ago. The heads themselves are a work of art. I doubt that you would be disappointed. It fired right up with an 800 rpm idle without a hitch. I was pleasantly surprised to find that the cam does not have a ton of lope at idle. Very nice. After a little break in it will be time to let her rip!
I have it set at 6500 from running over the winter. I'm going to up it to 6600 with my HPP until I can get the programming done, hopefully in the next couple of weeks. I'm sure I'm going to need the extra 200 rpm as I'm hoping for ~123mph in decent weather
I also have to say that Jayson was great. He answered everyone of my questions clearly and quickly, no matter how trivial.
Mark
Ram Air Tony says:
Cam specs: Hammer Cam
Duration at .050 intake/exhaust 222/222
Maximum lift with 1.7 rockers- .566/.566
Lobe separation- 112 with a 108 I/C
Vendor- MTI
Your car type (auto/manual) - M6
Displacement- 346
Headwork? (yes
Headers? (yes-shorty)
Forced induction/ Nitrous or N/A: n/a
Computer reprogrammed? (yes )
Throttle plate drilled? 1/8"
RWHP 427
RWTQ 395
Goals- (Street)
Is it too aggressive/not aggressive enough/just right? just right
Lope- (stock,burble,lumpy,chaotic) engine shakes
Additional comments :
The MTI stage II LS6 heads and hammer cam with SHORTY headers and CATS and put out 427 rwhp and 395 rwtq....idle at 900 and runs like a raped ape .... not a problem one.
Like Nike says..."JUST DO IT"
Cam Specs: Hammer
Dur. @ .50 - 222/222
lift int/exh - .566"/.566"
lobe sep. - 112
manufacturer - Comp
vendor - MTI
6 speed manual
346 cid
MTI Stage II heads
FLP long-tubes
Naturally Aspirated
Computer reprogrammed - MTI custom programmed
throttle plate drilled - yes Goals - daily driven/drag racing idle - very mild
lope - burble rwhp - 427 cut-out open/418 cut-out closed
rwtq - 405 - open/400 closed ET - 11.92 Nitto DR 120.19 mph race weight 3,500 lbs
comments : the cam idles very well, it's almost annoying - I'd like it to be slightly more aggressive, however, I can not argue with the results! I am very pleased with the Hammer cam.
Cam Specs: Hammer
lobe sep. - 112
manufacturer - Comp
vendor - MTI
6 speed manual
346 cid
MTI Stage II heads
Grotyohann long-tubes 3" ORYP
Naturally Aspirated
Computer reprogrammed - HPP3
throttle plate drilled - no
idle - very mild
lope - mild burble
rwhp - 411 cut-out open
rwtq - 390 - cut out open
ET - 11.23 ET Streets 122.78 mph race weight 3,450 lbs
Comments : The cam idles very well, I am very pleased with the Hammer cam. My car idles very well at 850 rpm without even drilling the TB or custom programming. It does not shake around at all or stall. It will surge a little when cold, but not when warm.
To see some hammer cam dynos go to:
http://xs-fx.com/raughammer/hammer_cam_dynos.htm
Also this thread may be of some use to you.
https://ls1tech.com/ubb/cgi-bin/ulti...c;f=1;t=004275
I thought also you might be interested in reading this UBB topic:
https://ls1tech.com/ubb/cgi-bin/ulti...c;f=1;t=003716
Old Sep 24, 2002 | 03:22 PM
jt093's Avatar
Thanks John...maybe i will see you around H-town
<img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" />
Old Sep 25, 2002 | 05:47 AM
LS1derfull's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by jt093:
<strong>BTW, I know I have an A4 but on your M6 does it idle rough?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Jeff, it idles great and you can hear it out back sounds tough. It does set random missfire codes intermittently, but runs very well even with ported maf and stock 3.42 gears. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
