5.3L motor specs?
I apparently spent to much time with the 5.7 that I never really kept up on the little brother motor!!
Bryan
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> The max you can go on the 5.3 block is 3.910 +-.005. We have sonic tested many and this about where you want to be bore wise. The cheapest combo is a 6.0 crank with 5.7 rods and pistons to make a 5.7. Call Barry or Wade at the shop and they prob. have some stuff around for a good price. The max stroke you can go is 4.125 which will yield 396 inches with the 3.905 bore. Hope this helps.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
<strong>
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"></strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Hmmm... The 5.3,5.7,and 6.0 cranks/rods are all the same as they have the same stroke. All you would need is the pistons/rings.
So, bore it and your expenses include the machine work and pistons/rings.
i believe it was the 99 and MAYBE the 2000 6.0L cranks that were a different part number from the ls1 cranks, but other than that yes.
