Piston to Valve Clearance
ouch!
So anyone know what can clear on a stock motor, with Trick Flow Heads?
w/ no milling?
or so i've heard.
so assuming stock gasket..you could run a bigger cam than you can on other heads...or possibly a thinner gasket.
but i think your question falls under the "if you have to ask..."
you may as well check to confirm
or so i've heard.
