Best reasons to get forged components?
Which should be first, a new rearend or forged engine components?
<strong>So would a car with just stage II heads and cam ever really need to upgrade?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No.
<strong>Does anyone make an inexpensive, hypereutectic or cast piston for a 3.905" bore? I'm close to doing a rebuild and don't have a lot of money to throw around. The engine's got 53K miles and it doesn't smoke so the rings are probably ok. Probably just needs a cleanup hone.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No. There are the overbore GM pistons and that's it.
Or you can go with Forged JE's or Diamond's. That's $600, plus you might as well spring for good rings.
Bret
<small>[ September 26, 2002, 05:37 AM: Message edited by: SSG--Z28 ]</small>
Because then the stock internals, hypereutectic pistons really will make a mess if a rod bolt lets go.
Track officials found many of my piston bits around the 1000 ft mark. Just a heads/cam too, redline at 6700 ;-)
Chris
<strong>I am thinking of going this route, but I want to know how it will benefit me the most.
Which should be first, a new rearend or forged engine components?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">LPE runs the 550 TT package on the stock motor. No probs.
He does upgrade the bottom end with the 650 TT package.
