timing chain oil pump :?
Old Sep 26, 2002 | 10:38 AM
iowass98's Avatar
Default timing chain oil pump :?
having the hotcam and macs with ory pipe installed next week.should i also change the timing chain and oil pump as well? or is this cam mild enough to live with the stock parts?
If i do cahnge should i go with the slp double roller? Whats the best replacement oil pump to buy and where? THanks
Old Sep 26, 2002 | 10:52 AM
HITMANSS's Avatar
Default Re: timing chain oil pump :?
The Katech oil pump and single chain is a nice setup. The SLP double roller is extremely stout, but there are spacing issues if you have an underdrive pulley.
