Car wont start.....need help
Old Sep 26, 2002 | 04:28 PM
TanRchy's Avatar
Default Car wont start.....need help
Not sure if this belongs here, but here goes. Car was low on gas (check gauges light) but it started up fine and idled. I tried resetting the OIL CHANGE light by turning the car off and pushing the gas pedal down three times. Now The car wont start. It fires and the fuel pump primes but it just wont turn over. I put a little more gas in but this didnt help. Did i flood my car?? What should i do? Thnx <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> p.s. I tried to push start it and that didnt work either....
Old Sep 26, 2002 | 08:35 PM
DONAIMIAN's Avatar
Default Re: Car wont start.....need help
Go to an auto parts store, and look for one for one of thoes lil scopes they have that fit inside your spark plug hole, and see if you see any gas just sitting there. Also check your plugs and see if theyre wet with gas.
Old Sep 26, 2002 | 08:42 PM
TanRchy's Avatar
hey, thnx for the idea. I fixed it.Im a retard My throttle was stuck wide open.I did the "fix-it" mod and now my car runs! <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
Old Sep 26, 2002 | 08:45 PM
wrencher's Avatar
wrencher
I don't see how pushing pedal down 3 times caused it to flood . Any f.i. car the only time fuel is put in engine crank & run only.If by chance your engine does flood hold gas pedal to floor while cranking , this puts pcm into clear flood mode & won't add any fuel as long as pedal is kept to floor.
Old Sep 26, 2002 | 11:00 PM
PewterZ's Avatar
To clear the oil change light you turn the key to the acc position and push and hold the trip reset button until the oil change light flashes then turn the key back off and then start the car. I have never heard pushing the gas pedal 3 times clears the light. Good that you got it fixed though.
Old Sep 27, 2002 | 01:31 AM
TanRchy's Avatar
Yea i didnt flood it, my throttle just got stuck wide open for some reason <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> . Anyway got the light fixed and the car runs great! <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" /> <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
