Low Oil Pressure, Possible Causes??
Also on some of the early CHRAs Incon added a inline oil orifice. On later CHRA's garrett added the orifice to the CHRA itself, no need for an inline orifice. Dought that has anything to do with your problem, since it was not there before engine work.
Gary
the diagnosis is.....
2 turned mains, 1 cooked and ready to spin, atleast 2 maybe 3 trashed steel caps, one trashed block and one trashed crank.
DOH!! <img border="0" alt="[barf]" title="" src="graemlins/gr_barf.gif" />
hope you get it runing again soon.
What gets me is that all the rod bearings were fine, but the mains were trashed. Unless i picked up some trash in the one bearing and it spun. Then the low oil pressure took out the other 2.
I'm already rounding up the new parts. It'll be back on the road soon enough.
But the question is why?
Is it possible those aftermarket caps were somehow at fault?
Steve
Did you have Katech align bore the mains with the studs and new caps and did you check the runout on the crank? Do you remember what the runout ended up being?
Hope you get it back together soon. Best of luck.
Just asking because main bearing clearance measurements won't mean much if crank runout is off.
Maybe and LS1 engine builder will jump in and elaborate on this for us.
nope, if it was bent I didn't know. But, it was the same crank and block from my last motor and never had any bearing issues in that motor.
dunno
How do the plugs look? When that happened to my motor, it was running lean. Melted 3 plugs real bad and trashed 3 cylinders.
Any ideas why I gave up on FI? Too dmaned expensive when something goes wrong. Best of luck getting her back together bradah. We will miss you at Norwalk.
<strong>I recall you talking about how hard the motor was to hand crank before you had the heads on. I remember thinking sounds bad, should not be that hard to spin over. Good luck!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">We figured that out. The bores were improperly honed, piston to bore clearance was way off. Should have been the sign of a cursed motor <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Yep Todd, no norwalk for me. Even had the new 3.73's installed friday and got my tires mounted getting ready to hook on a good track.
Car was running great, trapping in the 130's at the track. Just the oil pressure got worse and worse and I didn't crack into the motor soon enough i guess.
But, i got a line on a new block and crank already.
The caps were line honed and doweled in the block. I did check crank endplay/runout, I have the actual number in my build book but don't remember off hand. I do know it was in spec, as were all the clearances in the motor.
For piece of mind, I may just stick w/ the PM mains that come w/ the donor block i get.
You used ARP main studs right? You did them to 60ft/lbs?
I did a straightness runout on mine and it was less then .001" on a the stock rebalanced LS1 crank.
Curious & strange that you ate a main bearing so early.
