Should I do a test on GTP heads?
Old Sep 27, 2002 | 10:31 AM
RUF SS's Avatar
Default Should I do a test on GTP heads?
I was wondering! A lot of people have made lots of good power with GTP heads! You may know I had some problems with ARE heads (they were robbing me some RWHP). But after MTI fixed the heads I got my rwhp to where it supposed to be! Anyway, should I get GTP heads? Can I make more than 450 RWHP just by changing to GTP heads? Or should I just stick with what I have? I want to test them out!
My ARE (MTI fixed heads) are flowing 290-295 CFM. How much does GTP heads flow?
So, can anyone lone me some GTP heads to test? <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<small>[ September 27, 2002, 10:33 AM: Message edited by: RUF SS ]</small>
Old Sep 27, 2002 | 10:36 AM
kewlbrz's Avatar
Default Re: Should I do a test on GTP heads?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by RUF SS:
<strong>I was wondering! A lot of people have made lots of good power with GTP heads! You may know I had some problems with ARE heads (they were robbing me some RWHP). But after MTI fixed the heads I got my rwhp to where it supposed to be! Anyway, should I get GTP heads? Can I make more than 450 RWHP just by changing to GTP heads? Or should I just stick with what I have? I want to test them out!
So, can anyone lone me some GTP heads to test? <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What did MTI fix? Or did they just simply port them further?
Old Sep 27, 2002 | 10:47 AM
RUF SS's Avatar
MTI changed the valves, the seats, the springs, and retainers.
ARE use weird valves lengths and bad spring setup. The springs were hurting my heads because there were no seats for the springs too!! Now that made me really mad!!! But thank God that I did not give up in finding the problem, so I caught it in the time before it made any serous damage!
ARE satge 2 heads flowed 270-275 CFM
After MTI fixed the heads the flowed 290-295 CFM
Old Sep 27, 2002 | 10:49 AM
RUF SS's Avatar
MTI did not do any proting!
Old Sep 27, 2002 | 10:54 AM
VINCE's Avatar
Shorty Director
I think you would make some incredible gains with GTP, TEA, JPR, MTI, FMS, Jantzer, MMS, LGM, Cartek, etc.. I hope that ARE will start putting out a good product again now that they are under new management. For now you just have to decide if the change is worth another 15 to 30rwhp..
kewlbrz's Avatar
What valves type/sizes and springs are you using now.
thanks
Old Sep 27, 2002 | 10:57 AM
Fenris Ulf's Avatar
If those heads are just ARE portwork, you will definately pick up with some GTP heads. His standard stage 2s will be fine for your stock bore motor.
Old Sep 27, 2002 | 11:01 AM
383ss's Avatar
YES PLEASE DO!!!!
I also have a 382 stroker and am getting heads in the next couple months. I'd love to see some results of TEA or GTP heads!!!
I'd say GTP or TEA would flow in the 300-310 range and you'd pick up about 10rwhp peak and quite and more in the low and mid range.
<small>[ September 27, 2002, 11:03 AM: Message edited by: 383ss ]</small>
Old Sep 27, 2002 | 11:02 AM
RUF SS's Avatar
I am using 2.08 in. and 1.60 ex. I have no idea what MTI use for there heads. But I have what ever they are using in there setups!
If I could be in the 465+ rwhp from the heads swap! That would be very cool!
Old Sep 27, 2002 | 11:04 AM
383ss's Avatar
I'd go down to a 2.05 or preferably a 2.02. you don't need 2.08 with a stock bore!!! It may actually be hurting you.
Old Sep 27, 2002 | 11:06 AM
Smoke_ur_5.0's Avatar
The last set of GTPs that came through flowed 309 at .555-.575 lift. They are only 2.02 valves but that's all you need.
Old Sep 27, 2002 | 11:40 AM
RUF SS's Avatar
Anyone have GTP flow #s handy?
Old Sep 27, 2002 | 11:42 AM
jmX's Avatar
jmX
Ruf, a few things
1) I have flow sheets of my ARE heads flowed on the same bench as my GTP heads. Email me for the jpg.
2) My ARE heads didnt have proper spring seats either, and the spring pressure was setup very low for the very heavier valves they installed in my heads (new springs are being setup on them now for the next owner, along with seats).
3) I bet you will gain power from GTP heads. You can even send your ARE ones back to thunder racing to have them flow tested against your new heads if you decide to do this (like I did).
Old Sep 27, 2002 | 11:53 AM
RUF SS's Avatar
jmx,
your email does not show!
I just sent you a PM.
You could send me the flow #s to
talqattan@austin.rr.com
Thanks!
Old Sep 27, 2002 | 11:56 AM
NoGo's Avatar
JMX / Ruf SS
Did you guys have the older or newer set of ARE's heads?
There were some changes made to the valves, and the springs I believe for the older vs newer.
It would be helpful for some preventive maintenance. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Thanks in advance.
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Sep 27, 2002 | 11:58 AM
jmX's Avatar
jmX
Our heads were ordered over a year ago now so they are probably the older ones. Mine are at thunder racing now getting setup correctly so the next owner wont have high rpm problems like I did. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Old Sep 28, 2002 | 12:01 AM
99 Black Bird T/A's Avatar
I think new heads would be worth it.
MTI, TEA, GTP, JPR and maybe RGR I'd consider. I think you should talk with each shop about your application. With your extra cubes an LS6 head might be worth considering as the right building block for your new package.
Old Sep 28, 2002 | 10:47 AM
Ragtop 99's Avatar
If you are flowing 290 at .550 that's pretty decent. I'd look at the exhaust flow side. The ARE heads seem to be weaker in the exhaust. With ARE heads, the split duration cams make more power. I'd swap out the reverse split for 230/236 or similar cam of your choice with 4 - 6 degrees of extra duration on the exhaust side. A 230/236 will probably get 10 - 20 HP over your current cam and cost a lot less than heads.
Old Sep 28, 2002 | 10:02 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by VINCE:
<strong>I hope that ARE will start putting out a good product again now that they are under new management. For now you just have to decide if the change is worth another 15 to 30rwhp..</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What happened at ARE?
Why new management at ARE?
I read they changed to a 25% restock fee but didn't see anything else on their website.
Old Sep 29, 2002 | 07:55 AM
Ragtop 99's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> Why new management at ARE?
I believe that Wade has taken the shop over as Nick plans to concentrate more on racing.
