Lunati Stroker Kit ?
Old Mar 16, 2007 | 07:22 PM
joshluther's Avatar
Default Lunati Stroker Kit ?
What is the part on the left for? It was in the bag with the crank sprocket. Is it for the cam gear? I know what the part on the right is for.
Old Mar 16, 2007 | 07:31 PM
Boosted LS1's Avatar
Looks like something to centre something but why not machine the sprocket properly? Guess I dunno. Does it fit anything?
Boosted.
Old Mar 16, 2007 | 07:47 PM
joshluther's Avatar
The hex fits over the stud on the cam but obviously doesn't fit into the cam gear. There is no stud on the back of the crank for the flex plate but why would you need an eccentric there?
Old Mar 16, 2007 | 09:50 PM
FieroBob's Avatar
You might want to drop an email to Lunati with the picture. I'm sure somebody there will be able to tell you what the part is for. Good Luck.
Old Mar 16, 2007 | 10:07 PM
Ping King's Avatar
its to adjust the advance and retard of the cam. I have one made by comp (sister company) you put it on the cam dowel, then with all the cam bolts lookse you adjust the cam timing.
Old Mar 17, 2007 | 08:19 AM
Project GatTagO's Avatar
Comp and Lunati have nothing to do with eachother.
Andrew
Old Mar 17, 2007 | 11:56 AM
joshluther's Avatar
Someone must have seen one of these before.
