How to remove oil pan?
Old Sep 27, 2002 | 08:38 PM
WhynotSS's Avatar
Default How to remove oil pan?
I jacked up the enigne and loosened the 6 crossmember bolts and I still need an inch or two more. What am I doing wrong?
Old Sep 29, 2002 | 03:59 PM
WhynotSS's Avatar
Default Re: How to remove oil pan?
Somebody please help me out. I really want to get my engine back together next weekend!
<small>[ September 29, 2002, 03:59 PM: Message edited by: WhynotSS ]</small>
Old Sep 30, 2002 | 05:51 PM
AgaveCorvette's Avatar
You're probably not clearing the crankshaft. Rotate the crankshaft using the front bolt and the pan should come out just fine.
Old Sep 30, 2002 | 06:51 PM
WhynotSS's Avatar
I will try that. However, I can barely turn the crank either way because there is a lifter jammed somewhere in the connecting rods. It look like it is stuck on the tranny, not the crank.
Old Sep 30, 2002 | 06:52 PM
WhynotSS's Avatar
Do I have to remove the front struts?
<small>[ September 30, 2002, 06:53 PM: Message edited by: WhynotSS ]</small>
Old Oct 1, 2002 | 01:16 AM
Damian's Avatar
LSX Mechanic
This is how I dropped my oil pan today..
Got a top mount motor brace, bolted it to the block, and then started unbolting the k-member just enough to lower it down and give room for the oil pan to slide out. And yes, you will have to unbolt the strut assemblies to do this..
josh
