Engine Coolant Gauge Going Crazy? (Long)
I pulled into the parking lot at work after lunch and the engine coolant gauge dropped all the way down past zero and stayed there...like the gas gauge normally does after you turn the car off, only my car was still running. All other gauges were normal, the oil pressure, voltage, etc.
I turned the car off for a few minutes and re-started it and the coolant gauge didn't budge. It's almost as if the gauge itself is toast, but I was having acceleration problems when it was working and bouncing up and down, so I think something is not right?
It's funny that this happened when it was raining. I think my car hates water. I normally never drive in the rain since my SS is not my DD. Several times when I've had to take my car to a car wash, it started sputtering and idleing poorly after I'd gone through the car wash as if something was getting wet and causing my engine to run poorly. It always goes away when seemingly the car dries out.
Anyway, sorry for the length, but I have no idea what this could be?
I have FTRA, I didn't go through any large puddles, but maybe I needed to block it off? It did rain fairly hard here in Chicago today...just kind of a weird coincidence with the rain and the car wash thing? Something about the water. I should be able to drive in rain though! <img border="0" alt="[Banging Head]" title="" src="graemlins/gr_banghead.gif" />
<small>[ October 04, 2002, 03:26 PM: Message edited by: TAraysr ]</small>
