LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   How F'd up is my engine??? (https://ls1tech.com/forums/generation-iii-internal-engine/67912-how-fd-up-my-engine.html)
andy98Z Oct 5, 2002 05:23 PM
I was at the track trying to run 10's on spray with stock internals. My second run something happened...I hook up autotap and it showed I had severe miss-fires in cylinders 2 and 7. I drive it home with a little white smoke out the exhaust. Check my coolant level and it is low as hell. And pulled cylinder 2's plug and it looks fine although its green.
How bad is my car messed up?
Malicious Oct 5, 2002 05:26 PM
Re: How F'd up is my engine???
Sounds like a head gasket to me <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
DONAIMIAN Oct 5, 2002 05:32 PM
how big of a shot did you run through it. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Reckless Oct 5, 2002 07:46 PM
I bet it's ring lands. The stock pistons are bad about that. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
wrencher Oct 5, 2002 09:18 PM
OUCH!!! <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> Not the way to 10's , well maybe temporarly! Sounds like it's time to do some exploritory surgery & see what happened.
sited12 Oct 5, 2002 10:25 PM
Better just hope it is just a head gasket.
andy98Z Oct 5, 2002 10:41 PM
If worst comes to worst I will return it to stock and take it in for warranty.
So what are all the possible scenario's and prices?
Head gasket...no big deal? just some work?
Piston rings...tear apart whole block?
<small>[ October 05, 2002, 10:42 PM: Message edited by: andy98Z ]</small>
andy98Z Oct 5, 2002 10:45 PM
I had a single nozzle 167 jet from 5177 kit spraying through my air filter.
98TAauto Oct 5, 2002 10:54 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by andy98Z:
<strong>I had a single nozzle 167 jet from 5177 kit spraying through my air filter.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">please tell me you had you fuel pump upgraded for that shot???
white smoke means head gasket usually.. i hope thats all <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
99 Black Bird T/A Oct 5, 2002 11:25 PM
I hope is just a head gasket and nothing real serious.
However,
[QB]If worst comes to worst I will return it to stock and take it in for warranty.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Why should GM foot the bill for this? Seems to me if you were trying to spray your way into the 10's, it's not GM's responsibility to fix your engine.
Iv_z28 Oct 6, 2002 03:11 AM
Frankly, my opinion is that the dealer shops often try to screw up people. So if they get screwed once in return, I honestly won't pity them.
LS171Malibu Oct 6, 2002 05:48 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Iv_z28:
<strong>Frankly, my opinion is that the dealer shops often try to screw up people. So if they get screwed once in return, I honestly won't pity them.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I know that's right <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> Down with the service dept.
99 Black Bird T/A Oct 6, 2002 08:30 AM
<strong>Frankly, my opinion is that the dealer shops often try to screw up people. So if they get screwed once in return, I honestly won't pity them.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Using that type of thinking, if someone (dealer) steals from you or another person,it's ok for you to steal from someone else (GM)
<img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
MelloYellow Oct 6, 2002 09:42 AM
I don't remember this thread or title being a Q about ethics. Get over it.
OPEN PLZ Oct 6, 2002 09:51 AM
Are the stock rings an issue without nitrous at compression ratios of 11:1 or less, assuming good gas?
Hope it is only a head gasket.
Greg
andy98Z Oct 6, 2002 10:03 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 99 Black Bird T/A:
<strong>I hope is just a head gasket and nothing real serious.
I went 12.20's on motor so 10's isnt impossible with spray.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Why should GM foot the bill for this? Seems to me if you were trying to spray your way into the 10's, it's not GM's responsibility to fix your engine.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
andy98Z Oct 6, 2002 10:08 AM
Also...I had been running that shot in my 98 for 2 years and in the ss for atleast a month. Something else messed up that run..like the car didnt shift or something.
Scalpel Oct 6, 2002 11:22 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 98TAauto:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by andy98Z:
white smoke means head gasket usually.. i hope thats all <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The 5177 kit can only flow a max shot of 125 even with no jet in the fogger. (Assuming he has the powershot nozzles that come with the 5177 kit)
lafnatu Oct 6, 2002 11:46 AM
However,
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Why should GM foot the bill for this? Seems to me if you were trying to spray your way into the 10's, it's not GM's responsibility to fix your engine.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">whats gm ever done for you
lafnatu Oct 6, 2002 11:48 AM
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Iv_z28:
<img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">its sunday morning, shouldnt you be at church preaching <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
© 2026 MH Sub I, LLC dba Internet Brands
