383 update, reverse split baseline dyno
Old Oct 9, 2002 | 01:14 PM
VINCE's Avatar
Shorty Director
Default Re: 383 update, reverse split baseline dyno
Looking good..
Old Oct 9, 2002 | 05:37 PM
onfire's Avatar
Coal Mining Director
That's great info....can you post an overlay?
Old Oct 9, 2002 | 06:48 PM
Cmarsh93z's Avatar
How did it shift the powerband, where was peak, did you gain throught the curve?? Post up a graph!
Chris
Old Oct 9, 2002 | 06:55 PM
gator's 99TA's Avatar
i will get on him to post his graph. he is going to get it redynoed with a wideband. should be interesting though.
Old Oct 9, 2002 | 08:17 PM
John B's Avatar
Moderator
I'd be a bit nervous with a 14:1 A/F ratio!!!
Old Oct 10, 2002 | 12:24 AM
383ss's Avatar
Default 383 update, reverse split baseline dyno
did a baseline dyno yesterday, but couldn't do any tuning because we couldn't get autotap or LS1edit to connect to the PCM. HELP?!?!
best (3rd) run of:
456rwhp
435rwtq
a/f starts out at 11.5 till 4800 and then goes up linearly to 14:1 at 6800. I think there's quite a bit left in her. At least 460/440, probably more.
the change was from a 224/224 .539 114 lsa to a 236/232 .602/.575 112lsa cam.
Old Oct 10, 2002 | 09:50 AM
383ss's Avatar
I'll probably wait to get it tuned on the dyno and get the A/F right, then I'll post an overlay. I may post just this graph later today if I can get it scanned.
Old Oct 10, 2002 | 11:21 AM
W8N2SQZ's Avatar
Wow, sweet numbers wait until you get it tuned. Keep us updated and good luck.
Glenn
Old Oct 11, 2002 | 09:33 AM
ezss's Avatar
I had the problem of not being able to connect to the PCM before. Turned out it was a blown fuse. Its one located by the driver side door panel, should be an easy fix if that is your problem. Fuse can be had at radio shack.
Great numbers! keep us posted on the results. Is that a stroker or a bore setup?
Old Oct 11, 2002 | 09:35 AM
ezss's Avatar
oops just read your sig...ignore the stroker/bore question.
I am hoping to do an all bore 382 before the end of a race season...looking for numbers similar to yours, if my ARE heads will comply.
Old Oct 11, 2002 | 09:41 AM
LS1derfull's Avatar
Those performance times are before right?What was your power peak? TIA
Old Oct 11, 2002 | 11:28 AM
383ss's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by LS1derfull:
<strong>Those performance times are before right?What was your power peak? TIA</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">tq peak is at 4900, but stays above 420 from 4100-5500.
hp peak is 6300.
those are current performance times <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> , I'm acutally pretty happy with them for now. Before this cam my best was 12.5@112 on nitto's. Now comes the excuses <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" /> I FINALLY got a good clutch in the car that can launch well and hold the power. My tranny still CAN'T be power shifted or even speed shifted well for that matter and I'm still on stock 3.42 rear end. On my 11.7 run I hit the limiter in 2nd and ground the crap out of it, hit the limiter in 3rd also about 100' before the traps and never got into 4th.
