torque specs
Old Oct 10, 2002 | 05:50 AM
CamSS00's Avatar
Default torque specs
I can't find a book anywhere on my car. I just did a cam change and was wondering the torque specs on rocker arms,intake etc.
Thanks
Jeremie
Old Oct 10, 2002 | 07:39 AM
BigTex's Avatar
Default Re: torque specs
Here are few that you may or may not need:
Valve Rocker Arm Bolt - - - - 22 lb ft
Valve Rocker Arm Cover Bolt - 106 lb in
Camshaft Retainer Bolt - - - - 18 lb ft
Camshaft Sensor Bolt - - - - - 18 lb ft
Camshaft Sprocket Bolt - - - - 26 lb ft
Intake Manifold Bolt (First Pass in Sequence)- 44 lb in
Intake Manifold Bolt (Final Pass in Sequence)- 89 lb in
Engine Flywheel Bolt (First Pass in Sequence) - 15 lb ft
Engine Flywheel Bolt (Second Pass in Sequence) - 37 lb ft
Engine Flywheel Bolt (Final Pass in Sequence) - 74 lb ft
Oil Pump Bolt - - - - - - - 18 lb ft
Oil Pump Screen Bolt - - - 106 lb in
Oil Pump Screen Nut - - - - 18 lb ft
Engine Oil Filter - - - - - - 22 lb ft
Spark Plug - - - - - - - - - 11 lb ft
Good luck
Richard
