Why don't you change lifters???
EDIT: Or do a lot of people just leave them in to save some $$ and the hassle of taking off the intake?
<small>[ October 11, 2002, 01:09 AM: Message edited by: SSDriver ]</small>
<strong>it's mostly cause you have to take the head off to get to the lifters.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You don't need to take the heads off to get to the lifters, just the intake.
<small>[ October 11, 2002, 02:13 AM: Message edited by: SSDriver ]</small>
You don't need to take the heads off to get to the lifters, just the intake.[/QB]</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">SSDriver, On all Gen 3 GM engines including the LS1, it is necessary to remove both heads to gain access to the lifters. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<strong>I have noticed that almost everyone who changes their cam just changes their springs, retainers, timing chain, and pushrods. I would think that everyone would change their lifters as well. Correct me if I'm wrong but doesn't the lifter wear and some what form it self to your cam. If this is true wouldn't this in change wear your cam lobe's faster. I don't know every time I have changed a cam, I was taught to change lifters as well. I am not trying to be a smart ***, I just want to know WHY. Thanks for your time and help in advanced.
EDIT: Or do a lot of people just leave them in to save some $$ and the hassle of taking off the intake?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You should change flat lifters when you change cams...absolutely, and for the reason you said. Generally roller lifters don't have a problem because they roll, not slide, and rarely show wear.
Interestingly, GM service manual advises changing LS1 lifters if the cam is replaced. Hmmm.
FWIW, for a VERY low-buck rebuild of a flat lifter engine, it is possible to recondition the faces of flat lifters say when installing a $50 cam, but why bother; low-end flat lifters are a couple bucks each. No so for rollers!
When I do the short block I will look into new lifters (either stock or comp-r).
Mike
