How does this setup sound?
Old Mar 21, 2007 | 08:20 PM
yekta's Avatar
Default How does this setup sound?
My current setup is stock ls1 heads and GM ASA cam, which is a pretty annoying cam for a daily driven car
So I don't want to spend a whole lot of money but want the best possible with my budget.
This is what I came up with so far, how do you think this cam+heads would react?
CNC Ported LS6 / LS2 Heads from Patriot
http://www.patriot-performance.com/w...p?x=1&DID=1225
COMP Cams Xtreme XE-R Camshafts 224/230 .581/.588 .114
http://store.summitracing.com/partde...4%2D11&FROM=MG
I was thinking of Dart 225cc heads but then these heads from patriot are like $500 cheaper, do you think it is worth that money?
Old Mar 21, 2007 | 08:26 PM
shudog's Avatar
those durations are ridiculous. That can't be right can it?
No, I just checked the link, the durations you want to specify are 224/230. That's more like it. Probably good midrange. Very solid cam. Should idle relatively well with a 114 LSA. Reasonable lift won't kill springs either. Sounds like a great combo. I'm sure there are plenty others out there with a 224 cam and ported LS6 heads.
shudog's Avatar
Keep an eye on the sale forums and I bet you can pick up the cam & heads used for a great savings.
Old Mar 21, 2007 | 08:31 PM
shudog's Avatar
https://ls1tech.com/forums/lsx-parts-sale/677085-prc-ls6-cnc-ported-heads-500-miles.html
Old Mar 21, 2007 | 08:37 PM
yekta's Avatar
I don't want anything used bro, I saved a lot of money that way on this website before. Now its time to buy brand new
Besides these heads aren't too expensive for $1100 brand new.
yeah put the wrong numbers, my bad! fixed it.
