opinions on my cam choice
Old Oct 12, 2002 | 07:30 AM
JoSeY's Avatar
Default opinions on my cam choice
I want to go with a 228/232 .551/.551 114LS Comp cam. It will be on a full bolt on 4000 stall bottlefed 99' Formula....does anyone see a HUGE problem w/this cam on this set up? No heads, YET...but coming....THANKS in advance.
Old Oct 12, 2002 | 09:29 AM
VipZ28's Avatar
Default Re: opinions on my cam choice
PSH! That POS of your? <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> That cam is probly a BIT big for stock heads, not to say it won't run well, but i'm sure it will run rich, etc. etc. and not make quite the power a smaller cam would with stock heads, but if you're planning on heads later then it won't be quite so bad...
Until the heads though... <img border="0" alt="[Banging Head]" title="" src="graemlins/gr_banghead.gif" />
<small>[ October 12, 2002, 09:30 AM: Message edited by: VipZ28 ]</small>
Old Oct 12, 2002 | 11:59 AM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
Josey,
IMO. Call Geoff at Thunder. He is the one to ask for cam help. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old Oct 12, 2002 | 05:24 PM
CHRISPY's Avatar
Looks good <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I would consider getting around 4 degrees advance ground in <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
If your pistons will clear it a 230/234 on 112LSA will work great on spray and NA as well. (again 4 degrees ground into it)
Cheers,
Chris
Old Oct 14, 2002 | 12:21 AM
Fenris Ulf's Avatar
What do you want out of the cam? I would recomend running more aggressive ramps since supposedly the 918s can be trusted now, also I am not a fan of exhaust-biased splits, you should consider something like the TR230.
