anyone know the factory cam specs
Old Oct 12, 2002 | 05:37 PM
jonnyc's Avatar
Default anyone know the factory cam specs
trying to find out what size the factory cams are in the 02 ls1.
also if anyone else from california reads this,i would like to know what is the biggest cam that can pass a smog test here.
thanks
Old Oct 12, 2002 | 06:19 PM
RTCamaroSS's Avatar
Default Re: anyone know the factory cam specs
i think the stock cams are around .500 lift.. i may be wrong. I beleive its also on a 115 LSA. As far as the cali stuff goes.. check out www.norcal-ls1.com ..... Im putting the SLP cam in my 99 SS, im told it will pass smog no problem.
Old Oct 13, 2002 | 12:18 AM
strucksvt's Avatar
The lift is much smaller than the earlier LS1s. It's a .478 lift, but I have fogotten the duration (it's fairly low as well).
Old Oct 13, 2002 | 12:19 AM
strucksvt's Avatar
2001-2002 F-body LS1 Cam: 198/197 .478/.478 115 LSA
Found it. HTH
