Cam install question....
The stock GM chain is P/N 12552954, and can be had for about $30
Or, you can e-mail Darren at KB Engine Parts (Australia) and get a Jwis/Rollmaster Single Timing Set which includes the Jwis chain and Rollmaster timing gears for under $70 (delivered)
They also sell just the Jwis chain for a couple of bucks more than the stock GM chain price.
kbengineparts@hotmail.com
They also can get you the double chain Rollmaster Timing Set, but it will require you to shim the oil pump. You may not want to mess with all that.
I believe the Single Rollmaster Set will do you well and is stronger and of greater quality than the stock GM Timing Set.
Lots of choices <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
____________________________________________
<small>[ October 14, 2002, 09:52 PM: Message edited by: Kimchee and Rice ]</small>
Yes, I HIGLLY recommend that you DO NOT reuse the stock chain. You're already in there, replace it. If a chain breaks, bye bye heads, valves, etc. </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"><img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<strong>They also can get you the double chain Rollmaster Timing Set, but it will require you to shim the oil pump. You may not want to mess with all that.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If I were to go with the double chain (which seems the best), how much shim do I need to use? I have an 01. Who has the best price on these? Is this the "SLP" one?
Chris
<small>[ October 15, 2002, 06:55 PM: Message edited by: 2001CamaroGuy ]</small>
