View Poll Results: What coolant do you use in your LSx?
Dex-Cool
69.38%
Green Stuff
27.65%
Other (please specify in thread)
2.96%
Voters: 405. You may not vote on this poll
Offical Dex-Cool vs. Green Thread
Old Mar 24, 2007 | 02:10 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Keep an eye on the level, and Dexcool will never steer you wrong. It is a maintenance item, and should be treated as such.
Old Mar 24, 2007 | 02:12 PM
Tainted's Avatar
well on our cars they are normally hit in the front so the radiator breaks and we flush out the block and always use the green stuff. dexcool to us is just a problem because if it mixes with anything else youre fucked so we go with the green and havent ever had a problem
Old Mar 25, 2007 | 05:52 AM
VA2001SS's Avatar
Dex-Cool as well.
Old Mar 25, 2007 | 12:12 PM
Marc '99T/A's Avatar
Just curious....what would happen if you did mix the two?
Old Mar 25, 2007 | 04:04 PM
cool's Avatar
If the two are mixed, the dexcool loses its extended life properties. Thats all.
Old Mar 25, 2007 | 04:49 PM
Tainted's Avatar
if you mix them it makes a really nasty gunk that will clog **** up. ive tested it in an old radiator
Old Mar 25, 2007 | 08:38 PM
LSWon00's Avatar
This is the truth...people will tell you it will gel but thats false. Do some actual research and from automotive tech sites and coolant manufacturer sites and you will see that no gelling will occur.
Old Mar 25, 2007 | 08:54 PM
MS3Z's Avatar
I bought my car with the green stuff in it so I'll just stay with it.
Old Mar 25, 2007 | 10:13 PM
Rhedalert's Avatar
Apparantly GM uses some kind of gel-like cooling system sealant on problematic cars (mostly V6's with the intake gasket failures) this sealant likes to collect around the filler neck and make a mess. It's not the coolant itself doing it.
Old Mar 25, 2007 | 10:34 PM
SSwanner's Avatar
i am a GM technician and i really don't like the dexcool. every car i work on that has the stuff in it looks like crap. the radiatior cap has a blackish film on it and around the neck of the radiator.
on the other hand my dad use to run the prestone in his truck, (tow truck) changed it every year. he had to replace the radiator because it was stopped up.
i like & run mopar 100k mile coolant. its orange and works great. i never see any film buildup or rusting of my iron block 370. the stuff is about $20 a gallon though.
Old Mar 25, 2007 | 11:17 PM
cantdrv65's Avatar
Post
Originally Posted by LSWon00
There was just an article on this same issue in MotorAge magazine (ASE Tech Magazine). Long term studies have found Dex-Cool to erode "plastic" engine components over time. Their final conclusion was to switch to tradional (green) and change at the coolant's reccomended intervals. I personally have had no issue in my cars with Dex-Cool but I just thought I would post this.
This is the final word folks. In my experience this sounds SPOT ON....Motor age magazine is an EXCELLENT and HIGHLY respected source of tech information. Like I said before Dexcool issues are regarded as fact in the automotive repair world. Anything BUT Dex in all my rides.
Old Mar 26, 2007 | 01:29 PM
  #32
T|A's Avatar
T|A
i switched to green during the cam swap, no issues SO far
Old Mar 26, 2007 | 01:36 PM
  #33
tripps's Avatar
Been using Prestone Dex-cool since I bought the car. Only problem was at 96k the thermo wouldn't open, but i'm pretty sure that has nothing to do with what type coolant is being used.
Old Mar 27, 2007 | 09:46 PM
  #34
Rebel 92's Avatar
Yes. And I do know this from experience also. I have seen it myself.
Old Mar 27, 2007 | 10:55 PM
  #35
LSWon00's Avatar
Here it is again for all of you:
Old Mar 27, 2007 | 11:39 PM
  #36
Third Gear's Avatar
Now, that's what I'm talking about! That is some good information! So basically use distilled water (as you should) and anything but Death Cool and you'll be fine? Buy the G-05 if you use tap water, or use an Asian mix if you use distilled.
I'm considering switching to something else now. Anything metal I've seen in my engine looks perfectly clean... anything that is plastic seems to have that residue on it.... hmm...
Again, VERY GOOD information LSWon00. Keep it coming guys
Old Mar 28, 2007 | 01:16 PM
  #37
01pewterbird's Avatar
Sooo the "all makes all modles" Prestone, is like dex-cool??
Old Mar 28, 2007 | 04:06 PM
  #38
Third Gear's Avatar
That's what it appears to be according to the article
Old Mar 28, 2007 | 04:17 PM
  #39
well thats shitty. Now if air is the enemy of dex-cool, why is it run in the f-bod cooling system which isn't sealed??
Old May 25, 2007 | 03:32 PM
  #40
windshear's Avatar
Good point.
