What is the optimal spring pressure for TR224? Thanks.
Old Oct 16, 2002 | 03:38 PM
Scalpel's Avatar
Default What is the optimal spring pressure for TR224? Thanks.
Thanks.
Old Oct 16, 2002 | 05:34 PM
jmX's Avatar
jmX
Default Re: What is the optimal spring pressure for TR224? Thanks.
Depends how heavy your valves are.
My ARE heads had 130/305 (seat/open) pressure, but the valves were heavy as hell and it was insufficient.
My GTP heads first came with 918's setup at 130/310, but then I had double springs (987's) put in and I beleive they are now at 150/310.
So....300'ish open pressure looks to be what thunder racing is using.
Old Oct 16, 2002 | 05:36 PM
Scalpel's Avatar
They are Ferrera Valves 2.055 intake and 1.55 Exhaust valves if that helps.
Old Oct 16, 2002 | 05:48 PM
jmX's Avatar
jmX
The numbers I quoted are for 2.02/1.57 valves that came on the GTP heads. I don't know how your valves will compare weight wise to mine.
Old Oct 16, 2002 | 06:01 PM
LS1derfull's Avatar
Hydraulic lifters can only handle 330 lbs. open pressure i believe, are these bigger valves quoted 8mm stem diameter or .343" ?
Old Oct 17, 2002 | 03:19 PM
Speed Demon's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> Hydraulic lifters can only handle 330 lbs. open pressure i believe, are these bigger valves quoted 8mm stem diameter or .343" ?
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have stock lifters and my open pressure is @360 lbs. at 0.560 lift. I need to find my notes to find the exact lbs. figure. They are MMS springs.
