LG Cams?
Old Mar 24, 2007 | 09:15 PM
N4cer's Avatar
Originally Posted by 2000_SS
i don't want to have to call them to find out (lazy, i know) and if they won't tell me, why would i buy one from them?
Because their cams are great cams, of course. You must be new. Do a search. The results should show you why. And now that you know the specs, it's not an issue. Problem solved.
Originally Posted by AzzBustin30th
so is anyone 100% sure on the x3 specs. im bout to put one in my car and would like to know.
Yes. It's been said already.
234/242 .598/.610 112+4 or 114+4
Old Mar 24, 2007 | 11:05 PM
N2OGTO's Avatar
Wow...so they finally got out...
i've had both the X2 and X3...
Old Mar 25, 2007 | 01:16 AM
SLP4CamaroSS's Avatar
i know the specs but not going to say due to respect to lg. they grinded the specs off the cam but forgot to take it off the box weird
Old Mar 25, 2007 | 06:01 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
It doesnt really matter if you know or not. They tell you "yes it will fit" and "no it will not". If you really really wanted to be technical about it, that would cost you around $1000 ballparked.
Buy the cams and have them doctored.
You guys running the X3/X4 should have checked PTV on your own anyway....You know it is a big cam. That part is no secret. Hard to have serious overlap and not know what is going on.
Kudos to Louis and the guys at LG for keeping everyone guessing for all these years.
Old Mar 25, 2007 | 06:51 AM
PREDATOR-Z's Avatar
Should I post report cards??
Old Mar 25, 2007 | 02:32 PM
JPH's Avatar
JPH
that's funny.
Old Mar 26, 2007 | 11:12 AM
allngn_c5's Avatar
Just get the x3 with all necessary valvetrain upgrades. You will be happy, I know I am.
Old Mar 26, 2007 | 08:33 PM
PREDATOR-Z's Avatar
Hey Alingn_c5,
did you get your ride on the road again after those gasket issues?
Old Mar 27, 2007 | 09:01 AM
allngn_c5's Avatar
Hey Alingn_c5,
Car is at LG Motorsports as we speak. I am behind a few cars, so I won't know anything until towards the end of the week. Probably by Thursday I'll know if it is only the gaskets that had failed, or if I have something else going on. If its only gaskets then they will move fwd with the install of the ported 90/90 combo and tune it for me. If I have any problems with the block I'll be swapping parts over to an SLP aluminum 402. The 402 should make 480+ rwtq and over 500 rwhp with my parts.
********** Sorry didn't mean to hijack ******* Could've pm'd this ***
Old Mar 27, 2007 | 10:41 AM
2000_SS's Avatar
no problem, i'm thinking about a 402 as well, so i like to know what kind of numbers other people are getting with certain combos. i was looking at a TSP LS2 shortblock, with AFR 225's, and a 90/90 with a X3 cam.
Old Mar 27, 2007 | 01:54 PM
allngn_c5's Avatar
I think msguff with a 402 and afr 205's and x3 size cam made 515/480
I guy named gannon with a 408 and afr 225 did 535/500 if memory serves.
Old Mar 27, 2007 | 02:07 PM
  #32
z28misfit's Avatar
Originally Posted by N4cer
the two that i've seen checked turned out to be .598. did you measure that yourself to get that number?
Just got off of LG's website to make sure everyone here gets accurate specs on at least the lift part of the x3. It is .600"/.610."
Old Mar 27, 2007 | 04:15 PM
  #33
N4cer's Avatar
No, that's what they put on the site. In actuality, all that I've seen are spec'ing out at .598. That's accurate info. You don't have to take it personally. It's not your mission in life. I'm telling you what the 2 I've seen (and 3 others I heard about) spec'ed out at. It's a .598 lift cam. LIsted at .600 because that's what the lobe is in the catalog.
Old Mar 27, 2007 | 10:17 PM
  #34
tripps's Avatar
I can't wait to slap a LG cam in my car.
Old Mar 27, 2007 | 10:48 PM
  #35
PREDATOR-Z's Avatar
Advertized specs are in NO WAY accurate. Only cam doctor or Adcole will give the "TRUE" specs.
Exemple:
TR>>> T-REX cam advertised as:
242/248 - .608/.612 - 110 lsa
While in reality it is:
Old Mar 28, 2007 | 11:57 AM
  #36
2000_SS's Avatar
i've noticed over the past couple years that companies don't usually advertise the true specs of their cams. they aren't trying to mislead anyone, it's just really hard to duplicate exact specifications many times over. i think what they advertise is the average, or "goal," of what the cam should be. it's usually really close, not perfect, but close enough. that's a really good reason to check your cam out before you install it if you think clearance is even possibly going to be an issue.
