LS7 lifters?
Old Mar 23, 2007 | 04:18 PM
p8ntmunky's Avatar
Default LS7 lifters?
are these the ls7 lifters everyone is talking about and will i be able to run them with the stock length pushrods?
http://www.byunspeed.com/product_inf...7cdf5817d4a628
Old Mar 23, 2007 | 04:33 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
I believe those are the caddy lifters. SDPC has the LS7 lifters for less than $100...
Old Mar 23, 2007 | 04:34 PM
Xtnct00WS6's Avatar
Nope...those are even better. Those are the new CTSV lifters that were introducted here: https://ls1tech.com/forums/generation-iv-internal-engine/580686-new-upgraded-hydraulic-roller-lifters-sdpc.html
Old Mar 23, 2007 | 04:35 PM
Shinobi'sZ's Avatar
I'm looking for them too....I think these are the CTS-V lifters...
I am looking for the re-designed LS7 lifters...I think they are around $140.
Old Mar 23, 2007 | 04:36 PM
Shinobi'sZ's Avatar
You got a link or a part number?
Old Mar 23, 2007 | 04:57 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
We have the LS7 lifters in stock for $99.25! The CTSV Caddy lifters will be off back-order in a matter of weeks now!! They are $217.85.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Mar 23, 2007 | 06:29 PM
MannyZ28's Avatar
So how do the LS7 lifters compare to stock LS1 lifters? My car is a 98, so, I am taking a wild guess, along with the heads and rod bolts, and the oil pump, the 98 LS1 lifters are probably also of the extra shitty variety as is everything with 98 LS1's (looking at my valve covers with holes in the "wrong" location makes me sad).
For how big a cam are the LS7 lifters a worthwhile upgrade, and when do I start wasting money going to CTSV lifters? Right now I am just running a TR224 on a 112.
Old Mar 24, 2007 | 01:42 AM
p8ntmunky's Avatar
im going to run the torquer v3 with stage 2.5 prc 5.3l heads and i just wanna make sure i can rev nice and high with no worries. Since i was totally ready to spend 200 on them i guess ill just stick with these then considering there better then the ls7 ones.
So these will definately work with my setup and stock length rods right?
Old Mar 24, 2007 | 07:06 AM
ChevyChad's Avatar
The only reason to get caddy lifters is if you plan on revving over 7000 RPM...
Old Mar 24, 2007 | 09:41 AM
01Z0H6's Avatar
I am using the LS7 lifter with the 7.4 TSP hardened P/R... have worked fine for now...
Old Mar 24, 2007 | 09:59 AM
chriswtx's Avatar
The LS7 lifter is now all thats available from GM now for stock motors. It is the stock replacement for the LS1 lifter...The LS7 lifter will do fine for 99.9% of the guys out there...
Old Mar 24, 2007 | 10:02 AM
p8ntmunky's Avatar
well im gonna be revving to about 6500 and just wanna be safe will the ls7's be enough?
Old Mar 24, 2007 | 10:04 AM
chriswtx's Avatar
I'm using the new LS7 lifters in my new motor. Plan on setting the rev limiter at 7200rpm... My stock lifters handled 6700rpm just fine..
Old Mar 25, 2007 | 09:18 AM
davered00ss's Avatar
Moderator
I am alos looking for lifters and leaning towards the LS7 lifters. Just bought AFR heads.
Old Mar 25, 2007 | 10:27 AM
p8ntmunky's Avatar
where can i find the ls7 ones on your site?
Old Mar 25, 2007 | 10:52 AM
chriswtx's Avatar
set of 16 lifter kit part # 12499225
