382 Stroker questions...
Old Oct 20, 2002 | 09:29 PM
CamaroSS_2002's Avatar
Default 382 Stroker questions...
Do you have to bore out the block or does someone make a kit that doesn't require the block to be bored?
Would it be better to bore the block out if I have the option not to? why would it be better?
If someone makes a kit that doesn't require the block to be bored can you point me in their direction?
Thanks.
Old Oct 20, 2002 | 11:36 PM
SSilver's Avatar
Default Re: 382 Stroker questions...
for a 382 stroke no boring is required you can just buy the stroker kit from one of the sponsors like www.racenet.net or some of the other ones.
Old Oct 21, 2002 | 09:16 AM
99WhiteSS's Avatar
A .003" clean-up hone is needed to fit the pistons that come with the 4.00" stroker Lunati kit.
Old Oct 21, 2002 | 02:17 PM
LeadFoot2's Avatar
Chris at SpeedDemonMotorsports is running a GP right now for the Lunati kit (regulat about $4000, the GP has it for $3350).
They also mentioned that the kit comes in two "flavors" right now, but soon to only be one. Here is a quote from Chris in the GP section:
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> Actually, right now the kits come one of two ways(soon to only be the second of the two)
They either come 3.898, for the stock bore, no maachining required. and then a 3.903". </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">So, I'm guessing you can get the 3.898" pistons if you don't get the clean-up hone? But, if you have any kind of miles on it, you are probably better getting the 0.003" clean-up hone and going with the 3.903" pistons.
Can someone confirm?
Here's a link to the GP thread:
Stroker GP Thread
<small>[ October 21, 2002, 02:19 PM: Message edited by: LeadFoot2 ]</small>
