Oil pressure question
Old Oct 25, 2002 | 03:55 AM
oOoLy's Avatar
Default Oil pressure question
Here is my problem. After putting the car together I noticed that the warmer the car got the lower the oil pressure would go and was sitting in traffic today in HOT kuwait, until it hit the first line and remained there. Before it was up at 38-42 almost all the time under normal and hotter temperatures. What I mean is, I start the car it warms up and the pressure drops a little like it normally would. Then I would be stuck in traffic or idle for a long while (10+ min), the oil pressure would slowly start going down,than the engine stoped andi hear sounds from the left side. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
After that i tried to switch on the car but it did't work till it became cold.
When the RPM get more than 1500 it will shut down. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Thanks in advance
Adnan
Old Oct 25, 2002 | 06:09 AM
oOoLy's Avatar
Default Re: Oil pressure question
ttt
