LS1 PISTONS.......LOOK INSIDE
Thanks,
Chris Gelineau
Diamond Pistons
877-552-2112 toll free
cgelineau@diamondracing.net
LS1 PISTONS IN STOCK: FLAT TOPS & DISH PISTONS
P/N#/BORE/STROKE/ROD/C.D./WEIGHT/CC'S/PIN/COST
11500/3.905/3.622/6.098/1.340/405/-2CC/.945/$570
11502/3.905/3.622/6.125/1.315/404/-2CC/.927/$570
11503/3.905/3.622/6.125/1.315/431/-8.6CC/.927/$590
*#11503 IS OUR BLOWER/TURBO PISTON. THIS PISTON WILL HANDLE UP TO 20 PSI OF BOOST WITH OUT A PROBLEM.
11504/3.905/4.000/6.125/1.125/405/-7CC/.927/$590
11506/4.100/4.000/6.125/1.125/405/-7CC/.927/$590
11507/4.110/4.000/6.125/1.125/405/-7CC/.927/$590
11508/4.120/4.000/6.125/1.125/405/-7CC/.927/$590
11509/4.130/4.000/6.125/1.125/405/-7CC/.927/$590
ALL OF THE ABOVE PISTON SETS COME WITH PREMIUM 4130 WRIST PINS AND SPIRAL LOCKS. WE ALSO HAVE RINGS AVAILABLE FOR THESE SETS.
ABOVE SETS ALL HAVE 1.5/1.5/3MM RING STACKS.
Which rings? File fit? How much are rings?
Thanks!
<small>[ October 23, 2002, 09:10 AM: Message edited by: ls1290 ]</small>
Ls1290 - The dome pistons are going to be a custom for right now. That would run you $630.00 for a set. Wrist pins are also extra on the customs.
Thanks,
Chris
Trevor
<strong>What is the "C.D." number?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">This is the compression distance or compression height. It is the distance from the center of the pin bore to the top of the piston. Going to a longer connecting rod or larger stroke will require you to reduce the compression height. If not, the piston will stick further out of the bore.
All seriousness aside, thanks for the info. The iron block setup is a bunch cheaper than the sleeved aluminum route, but is still ain't cheap enough for my current finances.
I'll most likely just do a stock C.I. rebuild with decent rods and pistons and use the bottle for the big hp until I save up the needed small fortune for big N/A power.
ScottyG - "C/D" is compression distance. Jason99T/A described it well.
CamaroSS_2002 - Anyone of our pistons would be fine. They will all handle 10psi. If you wanted to be safe and lower your compression ratio a bit I would use our blower/turbo piston #11503. This is good up around 20psi. Also our stroker piston is #11504.
Thanks guy's,
Chris Gelineau
Diamond Pistons
Are low tension oil rings prudent in a street engine? I've seen some of the 3mm low tension oil rings used in some Ford products and they don't seem to be the way to go, especially for N2O engines. With the problem of smoking LS1's I would think that standard tension would be the way to go but I've been told there is no such ring in a 3mm oil ring? Just curious.
<strong>Chris,
Are low tension oil rings prudent in a street engine? I've seen some of the 3mm low tension oil rings used in some Ford products and they don't seem to be the way to go, especially for N2O engines. With the problem of smoking LS1's I would think that standard tension would be the way to go but I've been told there is no such ring in a 3mm oil ring? Just curious.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Brian,
Yeah I wouldn't be looking at low tensions on a NO2 engine, but if you have a low pressure or vaccum crankcase that's not that bad. As long as the rings are wide enough.
Bret
