milling heads and what size valves???
I am haveing a local engine builder port/polish and mill my heads. What is the most anyone has milled 5.7 heads with a TR 224/224 cam? What about with a TR 230/224 cam?
What size valve should I use?
options are as follows:
intake - 2.000, 2.020, 2.055, or 2.080
exhaust - 1.550, 1.575, 1.600
Some people say don't go any bigger than the 2.020/1.575 combo for street while the guy doing the work said "stuff the biggest thing you can fit."
What do I do? The car is for daily street driving and road racing (don't care about 1/4 mile).
Brian @ TEA
Like Brian said, you don't need anything bigger than that in your stock displacement daily driver.
<strong>Correct me if i'm wrong, but I believe the 2.02"/1.57" valves are the largest you can actually install in a 5.7 LS1 head and still use the stock valve seats.
Like Brian said, you don't need anything bigger than that in your stock displacement daily driver.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Ditto and not trying to be rude but if he is talking that way to you then I would find someone else to do the work because he is not experienced with ls1 heads.Bigger will hurt on stock displacement.If he believes bigger is better then he may hog out the heads.
You should have no problems milling your heads 0.040 along with the TR cam you have. If you stay with stock seats, the biggest valves you can go with are 2.02" intake and 1.57" exhaust.
