Pushrod length calculator inside!
Old Oct 29, 2002 | 03:20 PM
Scalpel's Avatar
Default Pushrod length calculator inside!
First measure your stock cam's base circe diameter. This is the widest point on the intake and exhaust lobes. Punch this into the stock cam base circle diameter.
Repeat this for your new cam's intake and exhaust lobes in the labelled cells.
Finally, if you milled your heads put in how much they were milled, i.e. 0.010 milled.
This will spit out the length of the pushrods required for your new cam and/or heads set-up. Thanks to Allcammedup for getting me straight on the math <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Here ya' go: http://home.insightbb.com/~l.proctor1/p-rod.xls
Enjoy!
This assumes stock spring installed height for an LS1. The stock pushrod size is base on an LS1 stock pushrod.
<small>[ October 29, 2002, 03:29 PM: Message edited by: NastyC5 ]</small>
Old Oct 29, 2002 | 08:06 PM
Tin Indian's Avatar
Default Re: Pushrod length calculator inside!
Neat! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Oh BTW, I think someone who has access to a set of calipers should go measure a stock pushrod and see if it is actually 7.400 inches.
I'm over in Korea right now, so, no help from me.
<small>[ October 29, 2002, 08:09 PM: Message edited by: Kimchee and Rice ]</small>
Old Oct 29, 2002 | 08:40 PM
Scalpel's Avatar
Kimchee, a stock p-rod is not 7.400". It's quite a bit smaller <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> . I measured one to be 7.375"
Old Oct 30, 2002 | 03:28 PM
Tin Indian's Avatar
Well, that puts a monkey wrench in everything I wrote in my thread!
Where the hell did this 7.40" number come from anywhere? We have allways been told the stock GM rod length is 7.40" by all the rod manufactures and sellers.
Now, I wonder if the aftermarket hardened 7.40" rods everyone advertises as stock length are really 7.40" or actually shorter!
Jeese... <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
_______________________________________________
<small>[ October 30, 2002, 03:29 PM: Message edited by: Kimchee and Rice ]</small>
Old Oct 30, 2002 | 09:55 PM
steve's Avatar
me and larry sample measured one some years ago and we came up with a 7.395 number.
thats where the 7.400 comes form. its close...
steve frank
Old Oct 30, 2002 | 10:17 PM
Tin Indian's Avatar
Steve...
The reason I said this is because NastyC5 measured one to be 7.375"
Thats .025" (25 thousands shorter than 7.40)(alot)
Steve, your 7.395" measurment is close (5 thousands)
