A slightly different version of Patrick G's cam
Old Mar 27, 2007 | 10:56 PM
MJE95GAGT's Avatar
Default A slightly different version of Patrick G's cam
I am trying to pick between two cams for 2.5 PRC 5.3s. I am aiming for a 6300-6400 shift point at most. The first is a 223/223 with LSK lobes on a 110+2 using 0.045 gaskets. With the VE spreadsheet that ends up having a 39.5 IVC, 43.5 EVO and a DCR of 8.80. The second is a 227/227 with LSK lobes on a 110+4 using 0.045 gaskets. That ends up having a 39.5 IVC, 47.5 EVO, and thus the same DCR of 8.80. Will either or both of these meet my needs of a powerful street cruiser that will only see the track 2-3 times a year? If both do, which do you think would better match the heads? I know the 223 would have a better midrange but the 227 will be slightly better on the top end. Which would give the best power under the curve? I am kind of stuck on these two because of the relatively low overlap compared to a split cam of the same size and since I don't need to carry the power very far past peak with the low shift points. Will that DCR be too high for 93 octane?
BTW this combo will be used with a SS3600 or SS4000.
Old Mar 28, 2007 | 09:05 AM
Patrick G's Avatar
LS1 Tech Administrator
Both will be excellent at meeting your needs. The 227/227 will make a little more overall power. Your actual DCR is going to be lower than 8.8:1 though. The 227 lobes check in closer to 279@ .006". Use this for your DCR calculations and you'll find it in acceptable range for 93 octane.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Mar 28, 2007 | 05:23 PM
MJE95GAGT's Avatar
hmm I didn't know that about the LSK lobes. Now I end up with a DCR of 8.73 Thanks! Anyone else? I don't think I have seen anyone yet with these exact specs?
Old Mar 28, 2007 | 05:30 PM
1997bird's Avatar
I have a 402 HR cam that is 278/278 Adv Dur., 239.75/239.72 @.050 Dur., 109.9+2, with .627"/.627" lift with 1.7 rockers. I'm not sure if that is what you meant though.
Old Mar 28, 2007 | 11:20 PM
MJE95GAGT's Avatar
240/240 is much bigger than what I am looking for but thanks. What is everyone thoughts about using a .040 gasket to achieve a DCR of 8.84? Would that be too high for 93? Will there be any PTV issues with the 227 and these heads?
Old Mar 29, 2007 | 08:03 AM
YellowToy/A's Avatar
That is alot of lift. What springs are you going to use? If you go with the .040 you will have a better quench. Which should help with knock.
Old Mar 29, 2007 | 08:15 AM
MJE95GAGT's Avatar
The springs that come with those heads are rated at .660" so I think I would be ok?
