Solved oil pressure problem
Old Oct 31, 2002 | 09:24 AM
RoyO's Avatar
Default Solved oil pressure problem
I just installed a new timong chain and gears in my T/A with the tr224 cam.Afterwards the oil pressure was low and lagging behind engine speed.After reading all of the posts I took the pump back apart and found that I had cut the oring between the pickup and the pump.With the new oring oil pressure is 37-40psi hot idle,about 50psi at 2,000rpm and 70psi at 6600rpm. Thanks for the info guys. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Nov 1, 2002 | 06:15 PM
99 Black Bird T/A's Avatar
Default Re: Solved oil pressure problem
Glad you got the problem resolved.
Old Nov 2, 2002 | 11:43 PM
EVIL's Avatar
sounds like i need to check that myself!
