5.3 heads
Old Oct 31, 2002 | 11:03 AM
roguevegals1's Avatar
Default 5.3 heads
getting a set of heads finally from TEA stage 2. they will be 5.3 heads. what options should i pick like in valve, milling and what will they flow at. i need to know this info so i can order asap please. also going in with a TR224/224 .561 112lsa cam. chould i change the vavle train up. if so in which way.
Old Oct 31, 2002 | 04:04 PM
Brian-GTP's Avatar
Default Re: 5.3 heads
Just call TEA, all of the good cylinder head shops can guide you using their experience to tell you what size valves and the chamber volume should be.
